pkaytes
Feb 08, 2025Guide
RS500 How often should DDNS send updates?
I'm taking advantage of the Netgear DDNS service. I would think that the router would periodically send an update to no-ip (the underlying DDNS provider) but I only see one update (the no-ip website ...
BH_C
Feb 08, 2025NETGEAR Expert
we will check it.
pkaytes
Mar 08, 2026Guide
I've installed fw 1.0.6.16 on the RS500 and it still does not update the DDNS provider (no-ip in my case) every 24 hours.
- StephenBMar 08, 2026Guru - Experienced User
Has the WAN IP address of the RS500 changed?
