Router2371
Dec 02, 2025Aspirant
RS500 MLO Support and 320MHZ?
HI
coolwifi
Dec 02, 2025Virtuoso
I can set my RS500 to 5.8 Gbps which is 320 mhz bandwidth. MLO is not yet available in Netgear wifi 7 routers. Do you have any client device supporting 320 mhz bandwidth?
- Router2371Dec 02, 2025Aspirant
Yes, my phone. On my asus router, the wifi analyzer shows the 320mhz. But on the rs500, it only shows up to the 160 as I stated. What channel are you on...any other settings you can share somewhere else in the system? If I put it to the 5.8, it drops to 20mhz every single time. I have tried with the 20/40 selection both off and on. No difference. Another person posted the same issue, only getting 20mhz when set to 5.8. Any help you can offer is appreciated.
- coolwifiDec 02, 2025Virtuoso
This is weird. I am on channel 69 auto selected by the router. But I don't have any wifi 7 devices to test the max bandwidth. Wifiman app shows the 6 Ghz channel in 320 Mhz bandwidth in my wifi 6E phone.
Getting different results with two wifi testers....wifi analyzer and wifiman....odd, no?
