Router2371
Dec 02, 2025Aspirant
RS500 MLO Support and 320MHZ?
HI
Router2371
Yes, my phone. On my asus router, the wifi analyzer shows the 320mhz. But on the rs500, it only shows up to the 160 as I stated. What channel are you on...any other settings you can share somewhere else in the system? If I put it to the 5.8, it drops to 20mhz every single time. I have tried with the 20/40 selection both off and on. No difference. Another person posted the same issue, only getting 20mhz when set to 5.8. Any help you can offer is appreciated.
coolwifi
Dec 02, 2025Virtuoso
This is weird. I am on channel 69 auto selected by the router. But I don't have any wifi 7 devices to test the max bandwidth. Wifiman app shows the 6 Ghz channel in 320 Mhz bandwidth in my wifi 6E phone.
- Router2371Dec 02, 2025Aspirant
Getting different results with two wifi testers....wifi analyzer and wifiman....odd, no?
- coolwifiDec 02, 2025Virtuoso
Yes looks odd, but I am using a different WifiAnalyzer app, may be it's the app issue in your case.
