coolwifi's avatar
coolwifi
Virtuoso
Jan 02, 2026
RS500 router - Internet feels much faster with IPV6 disabled?
Any insights why my internet and general browsing feels much faster with IPv6 disabled in the router. My ISP is Xfinity and it provides native Ipv6 support with DHCPv6-PD. The same has been my observation with my previous router R6700AX.
Also the internet speeds see a few Mbps increase with IPv4 only, although this is subjective. Definitely enabling IPV6 takes a toll on the router. It might be an ISP routing issue too.
  • coolwifi's avatar
    coolwifi
    Jan 05, 2026
    Speed tests would have variance at different times, I feel that the web pages load a bit faster and pings are slightly faster with ipv6 disabled, although the difference in performance is not huge.
  • FURRYe38's avatar
    Ok. FYI, the beta FW mentioned was released so it's most current.
    • coolwifi's avatar
      coolwifi
      Virtuoso
      You mean the latest FW for the RS500 router? It's still at 1.0.5.22 version.
      • FURRYe38's avatar
        Ya my bad. Was not fully awake when I posted that.
        Beta is still available if you wanna try it.
  • I have an RS700 and Ookla Speedtest reports and extra 15 Mbps down and extra 13 Mbps up with IPv 6 disabled. Using Cloudflare DNS.
    • coolwifi's avatar
      coolwifi
      Virtuoso
      Thanks, do the web pages seem to load a bit faster with ipv6 disabled? Also the latency has improved a bit. The YouTube videos in my Google TV streamer also load much faster.
      • LaddieParker's avatar
        LaddieParker
        Guide
        To be honest I don't notice any difference at all. The difference between 935 Mbps and 950 Mbps is negligible.
  • FURRYe38's avatar
    Tried custom IPv6 DNS to see if there is a difference?
    Also there is beta FW available I believe for the RS500...
    • coolwifi's avatar
      coolwifi
      Virtuoso
      Tried with custom ipv6 DNS, there's no difference. Will try the beta FW, but not sure if that will help with the dual stack ipv4 and ipv6 performance.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Using ISP detected IPv6 DNS or custom DNS?
    Is Protection Engine enabled on the RS router?
    • coolwifi's avatar
      coolwifi
      Virtuoso
      What Firmware version is currently loaded? Latest version 1.0.5.22
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Hitron Coda 56 modem
      Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. - Using Cat6a STP cable
      Using ISP detected IPv6 DNS or custom DNS? ISP DNS
      Is Protection Engine enabled on the RS router? No
      • FURRYe38's avatar
        Wondering if you had a chance to check the newest FW beta yet?
