bc5081
Jan 18, 2025Aspirant
rs500 slow upload speed
I am using Verizon fios 1 gig with a nighthawk rs500 and getting slow upload speed. Speeds measured using speedtest.net. I am showing wired speed but wifi speed is even worse at 2-3 mbps. Wired s...
Jan 18, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Protection Engine enabled on the RS routers WEB page under advanced tab/Security? If it is, try to disable this and reboot the RS router aftewards.
What devices are you using to speed test over wired and wireless?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
- bc5081Jan 18, 2025Aspirant
V1.0.1.60
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Alcatel-Lucent I-211-L
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.yes
It was. I disabled and rebooted to the same results.
Wired: HP desktop with a 1000/1000 realtek 'Gaming GbE Family Controller''
Wireless: Pixel 9 pro, Pixel 6, and a few android tablets.
