bc5081
Jan 18, 2025Aspirant
rs500 slow upload speed
I am using Verizon fios 1 gig with a nighthawk rs500 and getting slow upload speed. Speeds measured using speedtest.net. I am showing wired speed but wifi speed is even worse at 2-3 mbps. Wired s...
Jan 18, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Protection Engine enabled on the RS routers WEB page under advanced tab/Security? If it is, try to disable this and reboot the RS router aftewards.
What devices are you using to speed test over wired and wireless?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
bc5081
V1.0.1.60
Alcatel-Lucent I-211-L
yes
It was. I disabled and rebooted to the same results.
Wired: HP desktop with a 1000/1000 realtek 'Gaming GbE Family Controller''
Wireless: Pixel 9 pro, Pixel 6, and a few android tablets.
- FURRYe38Jan 23, 2025Guru - Experienced User
And what speeds do you see when you ethernet connect a PC directly to your ONT with out the RS connected?
- bc5081Jan 23, 2025Aspirant
- BH_CJan 23, 2025NETGEAR Expert
We noticed slow upload speed issues with certain ONTs like: Alcatel-Lucent 211M-L, Nokia G-211M-C, someone said they are the same model too. I guess Alcatel-Lucent I-211-L is actually the same model.
So far people reporting the issue used Verizon / FiOS service with the ONTs. We still work on the issue and, at this point, the issue is still open.
