bc5081
Jan 18, 2025Aspirant
rs500 slow upload speed
I am using Verizon fios 1 gig with a nighthawk rs500 and getting slow upload speed. Speeds measured using speedtest.net. I am showing wired speed but wifi speed is even worse at 2-3 mbps. Wired s...
bc5081
V1.0.1.60
Alcatel-Lucent I-211-L
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
yes
Is Protection Engine enabled on the RS routers WEB page under advanced tab/Security? If it is, try to disable this and reboot the RS router aftewards.
It was. I disabled and rebooted to the same results.
What devices are you using to speed test over wired and wireless?
Wired: HP desktop with a 1000/1000 realtek 'Gaming GbE Family Controller''
Wireless: Pixel 9 pro, Pixel 6, and a few android tablets.
Jan 23, 2025Guru - Experienced User
And what speeds do you see when you ethernet connect a PC directly to your ONT with out the RS connected?
- bc5081Jan 23, 2025Aspirant
- BH_CJan 23, 2025NETGEAR Expert
We noticed slow upload speed issues with certain ONTs like: Alcatel-Lucent 211M-L, Nokia G-211M-C, someone said they are the same model too. I guess Alcatel-Lucent I-211-L is actually the same model.
So far people reporting the issue used Verizon / FiOS service with the ONTs. We still work on the issue and, at this point, the issue is still open.
- Brian91223Feb 25, 2025AspirantI’m having the same issue. Just bought new RS200 and I’m getting very slow upload speeds with Verizon Fios. Has there been a fix for this yet?
