bc5081
Jan 18, 2025Aspirant
rs500 slow upload speed
I am using Verizon fios 1 gig with a nighthawk rs500 and getting slow upload speed. Speeds measured using speedtest.net. I am showing wired speed but wifi speed is even worse at 2-3 mbps. Wired s...
robotaxi228
May 24, 2025Aspirant
May I also get the beta firmware? The upload is unusable now.
- BH_CMay 24, 2025NETGEAR Expert
Hi robotaxi228,
What is the speed for your internet access service? If the speeds are 1Gbps or below, the release v1.0.1.90 on the link below should have it fixed. If your speed is higher than 1Gbps, please let me know and I will PM you the trial firmware for that.
https://kb.netgear.com/000066665/RS500-Firmware-Version-1-0-1-90
