bc5081
Jan 18, 2025Aspirant
rs500 slow upload speed
I am using Verizon fios 1 gig with a nighthawk rs500 and getting slow upload speed. Speeds measured using speedtest.net. I am showing wired speed but wifi speed is even worse at 2-3 mbps. Wired s...
BH_C
Jun 15, 2025NETGEAR Expert
When the speed slows down again,
* please check the speeds from the Nighthawk App.
* are you able to check the Ookla speed tests from a Ethernet connected computer?
Did you try other WiFi channels to see if that makes differences?
Thanks.
