tylerfire203
Dec 09, 2024Aspirant
RS500 unusably bad upload speeds
Am I missing a setting somewhere?!? What the heck could cause this? Summary of the situation: Upgrading from RAX80 (AX6000) to RS500 (BE12000) Gigabit Fiber at home 1gig up down symmetrical. ...
tylerfire203
Dec 11, 2024Aspirant
Yes, I have tried connected multiple computers to the router, the results are always the same. WiFi mirrors the same behavior with ~5Mbit upload speed.
Dec 16, 2024Guru - Experienced User
Any progress on this?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- tylerfire203Dec 16, 2024Aspirant
- FW: V1.0.1.60
- ISP already replaced the main LAN cable uplink. No change
- ISP doesn't use a modem its a fiber jack I believe. Regardless if I switch back to my RAX80 the problem goes away, so to me this is a Netgear issue.
Latest Update: I have contact netgear support and spent about 2 hours on the phone with them. We all the usual stuff that Tier1 offers: reset router, disabled security/Armor etc, disabled Smart Connect Wifi, changed out cables, tested with/without the router. Without the router we get 900/900 (directly connected to 1 PC).
We also used debug mode to do a capture and uploaded the results to their engineers to take a look. Waiting to hear back. They said they might need to create a beta firmware to fix the issue.
- FURRYe38Dec 16, 2024Guru - Experienced User
đ
