jjesso
Dec 07, 2025Aspirant
RS500 Upload speed test
I have an RS500 connected to Fiber modem. I have symmetrical 2G down and 2G up. Using the Netgear app, the Speedtest from the router shows 2G down no problem. My upload speed couldn’t get abo...
- Dec 07, 2025
BINGO! I should have thought of that!
PC hardwired in did the trick.
Full speed in both directions
Dec 07, 2025Guru - Experienced User
what modem is it connected to?
Do you have IPv6 enabled or disabled?
Have you tried a different speedtest site? Which are you using?
What are you device are you testing on?
Are you using parental controls/access controls? Try disabling and rebooting after disabled.
jjesso
The modem is a fiber modem from my ISP. I don’t have access to that part.
The Speedtest is from the Netgear RS500 router itself. When you log into the RS500web interface, it has a built in speed test function. Also same using the Netgear app on the phone.
I don’t have any access control controls enabled or Armor.
