harrison10098
Dec 15, 2024Follower
RS600 Internet dropping out consistently
So, I have just started using the RS600 and for the most part it has been good. About a day after use started I started experiencing internet cut outs on a pretty consistent basis. I have been thinki...
Dec 16, 2024Guru - Experienced User
some more details are needed.
1. what modem/gateway is connected?
2. what firmware are you on?
3. Is it all devices? just 2.4ghz device? just 5ghz devices?
4. are you using ipv6? Who's your isp?
5. is it specific devices with issues?
