grasshopper1969
Jan 02, 2025Guide
RS600 wifi issue on latest firmwire 1.0.0.60
I just purchased the RS600, first thing I did was update firmware to latest 1.0.0.60 then configured my setup. I have all SSID's separate for each frequency instead of 1 across all to save me from c...
Jan 04, 2025Guru - Experienced User
Just a thought.
I know its a lot of work, but the whole point of wifi 7 versus other versions is the increased bandsteering and concurrent band usage. That involves having the same ssids so devices can roam between bands and concurrently use them. Versus just stuck to one band. It kind of ruins the point of buying a high end wifi 7 system just to separate them out. And this will only get worse with newer versions. plus non of your wifi 7 capable devices are going to enjoy these benefits either.
You'd have been a bit better by saving the $ and getting an older generation router if that was your plan.
Again, not saying the behavior is correct, just saying, while its a PITA, to enjoy the benefits of wifi 7, nows the time to make the change versus a couple years later when you have even more wifi/IoT devices.
- grasshopper1969Jan 04, 2025Guide
Thanks for reply, I only purchased the RS600 as was roun $150 off on special at the time & main reason was for the x2 10GB ports to match up with my switch, wifi 7 was just the future proof for me. Looking deeper into the matter it may have something to do with the vlan tag group required for my connection to ISP for PPPoE to ONT as i have read other people having issue with wifi broadcast if this is enabled. Im quite happy at moment on 1.0.0.42 without 6GHZ band running as seems quite stable, think will wait for a future update to rectify issue.
- plemansJan 04, 2025Guru - Experienced User
Sounds good!
i would start switching devices to a unified ssid for the wifi 7 benefits. random day and slowly start moving them over. Seems like you got a pretty good deal. the RS600 is a rock solid device. I'm looking forward to whenever netgear starts incorporating mesh into their nighthawk like. It was announced with the RS700 but no further talk about it.
