grasshopper1969
Jan 02, 2025Guide
RS600 wifi issue on latest firmwire 1.0.0.60
I just purchased the RS600, first thing I did was update firmware to latest 1.0.0.60 then configured my setup. I have all SSID's separate for each frequency instead of 1 across all to save me from c...
grasshopper1969
Jan 07, 2025Guide
Just to update, I tried 1.0.0.56 as well this gave same result as 1.0.0.60 with separated SSIDs, showed under advanced home "wireless AP" was set to off even though all was turned on, also noticed on reboot from advanced home could not get router up and active, had to pull power for successful reboot. have moved back to 1.0.0.42 and all is back up as normal other than 6ghz only has download no upload.
