Andran
Mar 12, 2024Tutor
RS700 - Disable 5Ghz and 2.4Ghz band
I would like to disable the 2.4Ghz and 5Ghz bands on my RS700. I noticed that there is no option to do so in the settings. I tried disabling these bands by using the scheduler, but found that this do...
Mar 12, 2024Guru - Experienced User
Since each radio is a different frequency, they would not be generating interferences between each other.
If you have another router, then would be some interferences however if you change the channels between the RS and this other router to far apart channels then this would limit interferences between each wifi router. Distances between each other is important as well. Farther apart is recommended.
Is there any enable or disable broadcast on the RS web page under Advanced tab/Advanced Settings/Wireless settings?
- AndranMar 12, 2024Tutor
Thank you for the reply. No there is no option to enable the broadcast on the RS700 anywhere in the settings (including the advanced section on the web-page access. That is for the current firmware V1.0.7.82_2.0.80.
I tested another router (another brand, but also an expensive one) where for some reason performance on the 6Ghz improved by disabling the other bands, so I would like to do this on the RS700 as well.
- FURRYe38Mar 12, 2024Guru - Experienced User
Something that may not be supported on the RS.
Something to ask NG about.- AndranMar 13, 2024Tutor
I wanted to add that the scheduler can act as a work-around. I seem to have misconfigured something earlier, but it works now. I set a separate schedule with a daily start time of 3:30 am and end time of 3:00 am to disable the 2.4Ghz, and the 5Ghz bands, which means the bands I don't want are disabled most of the time (23.5 hours a day).
It works fine, but still seems a bit of an inelegant solution for such an expensive device.
Performance otherwise is top-notch for VR, though.
