Andran
Mar 12, 2024Tutor
RS700 - Disable 5Ghz and 2.4Ghz band
I would like to disable the 2.4Ghz and 5Ghz bands on my RS700. I noticed that there is no option to do so in the settings. I tried disabling these bands by using the scheduler, but found that this do...
Mar 12, 2024Guru - Experienced User
Something that may not be supported on the RS.
Something to ask NG about.
Andran
Mar 13, 2024Tutor
I wanted to add that the scheduler can act as a work-around. I seem to have misconfigured something earlier, but it works now. I set a separate schedule with a daily start time of 3:30 am and end time of 3:00 am to disable the 2.4Ghz, and the 5Ghz bands, which means the bands I don't want are disabled most of the time (23.5 hours a day).
It works fine, but still seems a bit of an inelegant solution for such an expensive device.
Performance otherwise is top-notch for VR, though.
- FURRYe38Mar 13, 2024Guru - Experienced User
Glad you found a work around then.
Thanks for sharing.
- BH_CMar 13, 2024NETGEAR Expert
Hi Andran, We removed the radio on/off function from RS700 due to some implemntation considerations. The WiFi Scheduler function turns off all bands, the 6GHz for your VR headset is turned off as well, so does the function work for you?
- AndranMar 14, 2024Tutor
Thank you for replying.
You say that the scheduler turns off all bands. However, thankfully this is not true.
I can use the scheduler to turn off the bands individually. So I set a separate schedule for the 2.4 Ghz band and the 5 Ghz band. I do not set a schedule for the 6 Ghz band, so that that does not turn off.
It works okay, except that the Wifi turns on the lower bands for half an hour each day, as can be seen in the log.
I would appreciate if you could add the option back in if it is possible. I can accept that this may not be possible, but yes if it is possible I would prefer that solution.
- Coliuto99May 12, 2024Tutor
I've just bought the RS700 and I can confirm that its not possible to disabling the Wifi network, even using the latest firmware 1.0.7.86
The scheduler is not an optimal option, because it still forces the wifi station to be turned back on for half an hour every day.At least, if the scheduler could be configured from minute to minute instead of from half hour to half hour it would certainly be much better
Couldn't you reintroduce the option to turn off wifi like in many other Netgear products?
It is quite surprising that for a product in this price range such basic options are lacking.
- BH_CMay 13, 2024NETGEAR Expert
We've been seriously considering to add the radio on/off function to RS700, but I just cannot share the timeline for the release. As soon as we have the trial firmware available before the official release, I will post it here. Thanks.
