pL86
Jan 10, 2025Tutor
RS700 - new firmware version 1.0.7.96 released
Almost 9 months since the prior 1.0.7.86 firmware was released, Netgear issued 1.0.7.96 yesterday. However, all the release notes says is "enhanced stability" so no mention if it adds MLO, fixes the...
DrunkKittie
Jan 28, 2025Guide
I'm having the same issue as Viperion.
Running V1.0.7.86. The router doesn't see the new firmware for almost 2 weeks, even after countless time of clicking "Check".
Manually uploading the firmware starts the process. After the restart, it still shows V1.0.7.86.
After a year of no firmware upgrades, no update on MLO support, now this.
Viperion
Jan 28, 2025Guide
My router got worse as Netgear support had me do a factory reset and once I did that it would not hold any settings, or upgrade still.
My router was RMA'd and they sent me a new one, the new one upgraded with the manual upgrade with no issues. working fine so far.
- DrunkKittieJan 28, 2025Guide
Viperion something similar happened to me around 6 months ago. I did a factory reset, and everything went downhill. Wifi stopped working, router interface didn't login. I did another reset (with proper old school, keep device unpowered, keep resetting the reset button style), devices stopped seeing the router altogether.
After 1 hour, and maybe 5 factory resets, it started working back again. Since then, I'm scared to reset it.
