pL86
Jan 10, 2025Tutor
RS700 - new firmware version 1.0.7.96 released
Almost 9 months since the prior 1.0.7.86 firmware was released, Netgear issued 1.0.7.96 yesterday. However, all the release notes says is "enhanced stability" so no mention if it adds MLO, fixes the...
Jan 28, 2025Guru - Experienced User
Might try Firefox or try the following, setup the router, off line from the ONT. Once one the home page go directly in and manually update the router with the .chk file.
Do you get any notice of a failure during the update or nothing and the FW version doesn't change?
BH_C
Jan 28, 2025NETGEAR Expert
We do staged rollout for every firmware release, so not every router could see new firmware when it looks for new versions. But manual upgrade still works (i.e. to download new firmware from the support site to a local disk, and then update the router with a local firmware file from the Web GUI)..
