pL86
Jan 11, 2025Tutor
RS700 - new firmware version 1.0.7.96 released
Almost 9 months since the prior 1.0.7.86 firmware was released, Netgear issued 1.0.7.96 yesterday. However, all the release notes says is "enhanced stability" so no mention if it adds MLO, fixes the...
mavere
Feb 12, 2025Aspirant
DrunkKittie wrote:No error message, after the router boots up it showed the old firmware version.
I tried the IOS app, it told me there is no new version available.
Just now, I tried manual update again, this time from Firefox, and this time it worked ok, and I can see it's updated to 96
Tried Safari first, and then Firefox. Neither browser for manual update worked for me, and just like you, the older version (86) still shows upon router reboot. I'm not going to worry about this for the time being.
BH_C
Feb 13, 2025NETGEAR Expert
Hi mavere, I've sent you a private message. Please reach out to the NETGEAR support team and let me know the case number. Thanks.
To reach the NETGER support,
* you can find the support phone number here https://my.netgear.com/support/contact.aspx, click on Contact Support, and you will see the NETGEAR support phone number 1-888-638-4327
* or you can go here https://www.netgear.com/support/, scroll down and you will see chat on bottom right.
- UrbanLegendMar 09, 2025Star
I had a similar issue to others on the thread where I was on 1.0.7.86 and I tried updating it (even though the router is set to auto update) via the Internet option and through manual update and it failed bac to 1.0.7.86 each time with no error. Then saw the mention of Edge (which I use) and to get Firefox (not gonna happen) so instead I gave the Nighthawk app a try from my phone and it applied 1.0.7.96 successfully without issue.
Nice to know that auto update couldn't/wouldn't even update though.
Never mind, it reverts to 1.0.7.86 even though the app said successful.
- FURRYe38Mar 09, 2025Guru - Experienced User
Does manually applying the FW update work at all?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Tried manual updates and while there are no reports of it failing but seems to go back to the older firmware still.
As a test, I disabled the auto updating just in case it was that causing it to roll back and then updated again with the app and it shows as 1.0.7.96 but then a few minutes after its finished rebooting it shows back up as 1.0.7.86 in both web admin and in the app.
In Logs it just shows: "[Initialized, firmware version: V1.0.7.86_2.0.82] Sunday, Mar 09, 2025 13:35:31"
Don't see anywhere in the logs that it ever initialized 1.0.7.96 only the internet disconnects as it rebooted.
- BH_CMar 10, 2025NETGEAR Expert
- FerbueMar 10, 2025TutorI'm having exactly the same issue as UrbanLegend I couldn't update manually and after trying through the app with the it says success (after a few tries) but it gets reverted to .86 again and again
- FURRYe38Mar 10, 2025Guru - Experienced User
Does this path work at all?
Ferbue wrote:
I'm having exactly the same issue. I couldn't update manually and after trying through the app with the it says success (after a few tries) but it gets reverted to .86 again and again - FerbueMar 10, 2025TutorThat doesn't work and I tried several times as well :S
