pL86
Jan 10, 2025Tutor
RS700 - new firmware version 1.0.7.96 released
Almost 9 months since the prior 1.0.7.86 firmware was released, Netgear issued 1.0.7.96 yesterday. However, all the release notes says is "enhanced stability" so no mention if it adds MLO, fixes the...
Viperion
Jan 11, 2025Guide
I tried the new 1.0.7.96 and it fails. my Rs700 won't accept it.
gjblajian
Apr 04, 2025Star
Same issue. Fails one of the updates and reverts (after several minutes updating and rebooting). VERY irritating. Not super fond of the fact that NETGEAR pushes you to the community forum when the issue is on their side either. If any company pushes out an update that fails, you should not need a support contract to report or track that failure. I get that you cannot just ask them to help you, but the only way the issue gets fixed is for them to do something to the firmware code to fix it and for that they need to be aware of the issue and tracking it.
- FURRYe38Apr 04, 2025Guru - Experienced User
You'll need to reach out to NG support and ask for help and information from them. This is all beyond forum help.
Good Luck
- ViperionMay 05, 2025Guide
Unfortunately, for the RS700 series, Netgear has not lived up to its name or brand reliability over the years. I had the same issues others had, and an RMA was required, but even after that. This router for wifi 7 does not work at the level I would expect. I have noticed on this one and the previous one it doesn't hold the wifi 7 connection well and drops to a lower standard to often. seems buggy to me. which goes to the lack of router firmware updates one would expect from Netgear.
