ljg1000
Apr 25, 2023Tutor
RS700- and Wifi 7 Certification
The WiFi alliance has not certified Wifi 7 products yet. Yet the RS700 (which at the moment have on pre-order), as well as similar products from TP-Link and Asus are on or will be on preorder. Will t...
microchip8
Apr 25, 2023Master
You ask questions that cannot be answered at this point in time.
- ljg1000Apr 27, 2023Tutor
Or don't want to be answered. Asking about pre-certification is a yes or no type question. Asking about customer protection if the new croup of routers can not fully certified at a later date- is valid and would be a matter of corporate policy (and the degree of customer orientation). Also if there is a chance it won't be fully certified, - it should be clearly mentioned in the product literature.
It is true that asking about support life is difficult to answer- primarily because if the router OS cannot be successfully patched to avoid security threats- it becomes unsupportable- and this might be hard to predict unless the OS is dated on release. Asking that if the router can be patched, it will receive security updates after X years is reasonable.- microchip8Apr 27, 2023MasterThis is a user-to-user community forum - we do not have pre-knowledge of what NG is thinking or will do. If you want some of the questions answered, ask NETGEAR directly.
I was hoping they would reply here. I doubt Pre-Sales would have the answers to these questions.
