ljg1000
Apr 25, 2023Tutor
RS700- and Wifi 7 Certification
The WiFi alliance has not certified Wifi 7 products yet. Yet the RS700 (which at the moment have on pre-order), as well as similar products from TP-Link and Asus are on or will be on preorder. Will t...
ljg1000
May 26, 2023Tutor
Also, I should add the BE800/BE900 doesn't yet have Wifi 7 back haul support and I believe the RS700 will. For those that need mesh solutions- the RS700 may be worth the wait- though the TP Link BE85 is out now- and I believe it does have Wifi 7 back haul support.
microchip8
May 26, 2023Master
Good luck on the updates. TP-Link is basically abandonware after they push a few updates.
