Darth_Blackcat
Jan 30, 2025Aspirant
RS700 2.5gbps WAN internet but only getting 1gbps on LAN5
Been scratching my head to figure out this bottleneck. My WAN shows 2.5 per the router settings being detected. I have my main computer on LAN5 since this is a 10gbps and shows 2.5 in the attache...
- Feb 07, 2025
Found the root cause.
Within my Ethernet controller adapter settings, I found "cFosSpeed for faster Internet connections (NDIS 6) and had it disabled. As soon as I disabled it, I could get my full 2.5 GB speed. This was the root cause for my bottleneck keeping the connection at 1GB.
DarrenM
Feb 06, 2025Sr. NETGEAR Moderator
https://www.downloads.netgear.com/files/GDC/RS700S/RS700_UM_EN.pdf
You may want to check out page 37 in the manual to set up multi-gigabit Internet with Internet port aggregation.
Thanks
DarrenM
Darth_Blackcat
Feb 07, 2025Aspirant
