Darth_Blackcat
Jan 30, 2025Aspirant
RS700 2.5gbps WAN internet but only getting 1gbps on LAN5
Been scratching my head to figure out this bottleneck. My WAN shows 2.5 per the router settings being detected. I have my main computer on LAN5 since this is a 10gbps and shows 2.5 in the attache...
- Feb 07, 2025
Found the root cause.
Within my Ethernet controller adapter settings, I found "cFosSpeed for faster Internet connections (NDIS 6) and had it disabled. As soon as I disabled it, I could get my full 2.5 GB speed. This was the root cause for my bottleneck keeping the connection at 1GB.
Darth_Blackcat
Feb 07, 2025Aspirant
Feb 07, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
