firemaguy
May 05, 2024Aspirant
RS700 6GHz band not visible
Have just upgraded my router to RS700s. I can't get my client devices (Samsung Galaxy Z Fold 5 and iPad Pro 11" (gen4)) to connect to the 6GHz band. I'm sure my client devices support Wifi 6E but they...
firemaguy
May 07, 2024Aspirant
Firmware version is latest 1.0.7.86.
Modem is Huawei EchoLife HG8040H
Tried to scan wifi signal across the whole 6GHz band on my mobile, no 6GHz signal could be found.
I can only disable Wifi security on the 2.4 and 5GHz band, 6GHz one is fixed to WPA3. Still no 6GHz signal if I disable the 2.4/5G Wifi security. Also tried factory reset and setup from scratch. Still no luck.
BH_C
May 07, 2024NETGEAR Expert
Hi firemaguy, did you set different SSID for different band? if you have done that, can you go to the router's management Web GUI, go to the ADVANCED tab, then get the screenshots for the Wireless Settings (6GHz) like below?
Thanks.
- firemaguyMay 09, 2024AspirantHave tried both Smart Connect and separate SSID for different band. Still can't find the 6GHz band. Please refer to the screenshot below. Thanks.
