Gonzo190
Mar 26, 2024Aspirant
RS700 Band Disable - Connects All Devices to the 2.4 GHz Band - Less than 10 Feet From Router
I have read that there is NOT a way to turn off the 2.4GHz and 5GHz bands. I have also read that there is a scheduler that can be used to control the bands. I cannot find it. I have went through the ...
microchip8
Mar 26, 2024Master
Don't use crappy apps. Use the Web UI of the router. Far more control.
Gonzo190
routerlogin.net does not do anything when I login.
routerlogin.com only gives me the option to change the password.
What am I doing wrong?
- FURRYe38Mar 27, 2024Guru - Experienced User
Try a different browser, MS Edge, Firefox or Opera.
Be sure to clear out all browser caches before entering 192.168.1.1?
- michaelkenwardMar 31, 2024Guru - Experienced User
Can be a sign that you have another router, maybe a modem/router, sitting between the RS700 and the Internet.
