Sozzled
May 13, 2024Aspirant
RS700 blocking connection to office VPN
I use a VPN when I am working from home to access the server in my office on the office network. I do this just by configuring the vpn in windows and connecting. Since I purchased the RS700 a few w...
BH_C
May 13, 2024NETGEAR Expert
Hi Sozzled,
There was a VPN pass through issue reported previously (Windows VPN client could not connect to the corporate server in the remote), and we have fixed the issue for that customer. I will PM you the link for the trial firmware, would you like to give it a try?
Sozzled
May 15, 2024Aspirant
It worked. Thanks
- FURRYe38May 15, 2024Guru - Experienced User
Enjoy. 📡
