Sozzled
May 13, 2024Aspirant
RS700 blocking connection to office VPN
I use a VPN when I am working from home to access the server in my office on the office network. I do this just by configuring the vpn in windows and connecting. Since I purchased the RS700 a few w...
valbosc
May 12, 2025Aspirant
Thanks, I received. I just check my router is RS300 instead of 700, does the same firmware works?
BH_C
May 12, 2025NETGEAR Expert
The RS700 firmware cannot be used on RS300.
I've seen some people complaining about VPN pass-through on RS300, but we could not really duplicate the problems in our tests. You may try the latest release v1.0.1.90 (link below) to see if that works for you.
https://kb.netgear.com/000066656/RS300-Firmware-Version-1-0-1-90
- valboscMay 12, 2025Aspirant
Thanks for the response. I updated but the problem persist.
No solution available apparently
