TeamCorvette
Mar 20, 2025Tutor
RS700 does not install new Netgear update
Hi Folks I have a RS700 Netgear update problem I hope you can solve wih a fix Router is set as you see in this screenprint to do auto upgrades but it never does. So I went on Netgear website and do...
- Mar 26, 2025
Glad the new unit is working.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
Mar 20, 2025Guru - Experienced User
You'll need to reach out to NG support then.
TeamCorvette
Mar 20, 2025Tutor
Netgear website support webpage says support for this $700 router I bought just last year no further support unless I pay them đ
I tried filing a need for support ticket and it rejected it again saying support for my RS700 ended 3 months ago
