TeamCorvette
Mar 20, 2025Tutor
RS700 does not install new Netgear update
Hi Folks I have a RS700 Netgear update problem I hope you can solve wih a fix Router is set as you see in this screenprint to do auto upgrades but it never does. So I went on Netgear website and do...
- Mar 26, 2025
Glad the new unit is working.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Mar 20, 2025Guru - Experienced User
Did you try the old nuclear option of a factory reset and reinstall?
TeamCorvette
Mar 20, 2025Tutor
No I did not because I found another thread on this subject on here to find out this has been reported like 50 times since start of this year where others have the same problem as I do and went told to do that reset that after that the router would be all fouled up
So here it is 3 months later and Netgear never solved this failure on firmware upgrades of firmware
As it is reading those posts when .96 came out in January, my router kept saying there was no upgrades and also auto upgrade was set on
Not until 3 days ago did my RS700 finally show new version needed to be done yet all paths to do so say sucess when upgrade is done but than showing old version still running and router page saying new upgrade is needed
I have used many Netgear products including cheaper routers of theirs and this $700 RS700 is a dog with no support and very few firmware upgrades since owning for 15 months
For some reason RS700 is treated like a step child and ignored by Netgear
Had the same failure when firmware is .82 and when .86 came out the same falure when doing that upgrade and when going to support got no answer on resulting the failure on upgrades
- FURRYe38Mar 21, 2025Guru - Experienced User
Something to try is the Factory reset and setup from scratch. If this fails then reach out to NG support and ask about an RMA option.
- BH_CMar 21, 2025NETGEAR Expert
I've reached out to TeamCorvette to work on the issue. Thanks.
- TeamCorvetteMar 21, 2025Tutor
I emailed you the 3 megs debug.zip file from the RS700 and contacted you via PM
Thanks for any help resolving this
JR
