TeamCorvette
Mar 19, 2025Tutor
RS700 does not install new Netgear update
Hi Folks I have a RS700 Netgear update problem I hope you can solve wih a fix Router is set as you see in this screenprint to do auto upgrades but it never does. So I went on Netgear website and do...
- Mar 26, 2025
Glad the new unit is working.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
TeamCorvette
Mar 22, 2025Tutor
Good Idea, I will ask them to as not looking forward with a new R700 also having this problem
