Rhubbard97
Aug 08, 2024Aspirant
RS700 ethernet port issues
As it says in the description, my ethernet ports are giving me trouble. I bought this router back in May and it has worked great until recently. Every morning when I turn on my work computer, conne...
Aug 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What brand and model# are these ethernet connected PCs and devices?
What brand and model# are the ethernet adapters in the PCs?
Ensure any ethernet adapter driver in PCs is updated from it's Mfr.
What CAT# LAN cable are you using between the router and ethernet connected devices? CAT6 is recommended. If your using a high speed ethernet adapter at the PC, 2.5Gb or beyond, then CAT6A STP is recommended.
