Rhubbard97
Aug 08, 2024Aspirant
RS700 ethernet port issues
As it says in the description, my ethernet ports are giving me trouble. I bought this router back in May and it has worked great until recently. Every morning when I turn on my work computer, conne...
Aug 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What brand and model# are these ethernet connected PCs and devices?
What brand and model# are the ethernet adapters in the PCs?
Ensure any ethernet adapter driver in PCs is updated from it's Mfr.
What CAT# LAN cable are you using between the router and ethernet connected devices? CAT6 is recommended. If your using a high speed ethernet adapter at the PC, 2.5Gb or beyond, then CAT6A STP is recommended.
Rhubbard97
My isp, Comcast, provided me with an XB8-T modem.
The ethernet cable is from Orbram, RJ45 flat cable Cat 8.
1st device: Dell latitude 5501
Ethernet adapter: intel I219-LM ethernet 802.3
2nd device: custom built windows PC
No factory reset has been attempted.
- FURRYe38Aug 08, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...Please change out the flat CAT8 cable for a thicker CAT6A STP cable between the ISP modem and the RS WAN port.
Ensure the ethernet adapter drivers are using most current driver from Intel.
Might factory reset the RS and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router- Rhubbard97Aug 08, 2024AspirantMy ISP modem has been set in bridge mode since purchase and I would not blame the cables either. I can verify that I am getting strong internet from them.
My ethernet drivers are up to date.
Is a factory reset your only suggestion?- FURRYe38Aug 08, 2024Guru - Experienced User
Yes. If after that the problem still happens, you'll need to contact NG support and open up a support ticket.
