Guy_T
Oct 29, 2023Aspirant
RS700 fast WIFI and Internet but slow across the network.
This is using firmware V1.0.7.66. I have two synology NAS connected to the router that I can only get about 150mbits to and from when accessing them from a wireless laptop but when i connect via et...
Razor512
Nov 12, 2023Prodigy
If you are getting faster speeds over the same WiFi connection to the WAN, but slow on the NAS, then check if you are using a split tunnel option on any VPN software if using any. Also check of write speeds are similarly low.
