nospeak
Nov 25, 2024Aspirant
RS700 firewall
hi… i do not want to use netgear armor on the router and was wondering if i deactivated it will i still have firewall protection other then the netgear armor….i do not like bitdefender
- Nov 25, 2024
Default should be good. Nothing to configure unless you need something specific.
Nov 25, 2024Guru - Experienced User
You do.
I rarely use armor. I might test it for the first 30 days after getting a new router and then just disable it.
