Topology
Nov 14, 2023Virtuoso
RS700: Heat Management
My understanding is that the Nighthawk RS700 Tri-Band WiFi 7 Router is not equipped with an internal fan, and relies only on passive heat dissipation. How well is the router able to manage heat, und...
Topology
Nov 15, 2023Virtuoso
FURRYe38, [1] are you using a fan with the RS700 router as a preventative measure, or because you have noticed the device becoming warm or hot without a fan?
[2] How do you position your 120mm USB fan to cool the RS700? Does the router have open airflow slots on its bottom, and do you stand the router on the top of the fan in order to blow cool air up and into the router?
Thank you.
Nov 15, 2023Guru - Experienced User
Thought I don't have an RS yet, the fan is a " preventative measure" for ANY router I have online. One sits on top of my RBR971 currently and one sits under my RBR850 currently.
- TopologyNov 17, 2023Virtuoso
Individuals interested in using a fan to cool a router may wish to consider products by AC Infinity (e.g., see here and here).
- FURRYe38Nov 17, 2023Guru - Experienced User
I've found the fan off Amazon to be well sufficent for additional cooling. Cheep too.
- TopologyNov 21, 2023Virtuoso
I am curious to hear from NETGEAR Community members about their experiences with the RS700 in regard to router's use of passive heat dissipation: how well is the router able to successfully manage heat, under ‘normal’ and ‘heavy’ usage conditions? (Thank you.)
