Topology's avatar
Topology
Virtuoso
Nov 14, 2023
RS700:  Heat Management
My understanding is that the Nighthawk RS700 Tri-Band WiFi 7 Router is not equipped with an internal fan, and relies only on passive heat dissipation.  How well is the router able to manage heat, und...
