FattiesGoneWild
Apr 15, 2024Guide
RS700 ipv6 configuration with Spectrum internet
Spectrum says contact Netgear and Netgear says contact Spectrum. Does anyone know the correct configuration to use in the router settings? It’s disabled by default.
FattiesGoneWild
Apr 20, 2024Guide
DHCP is the option you want to use.
FattiesGoneWild
Aug 29, 2025Guide
Under LAN setup, leave it on auto config or change to DHCP?
