Baily
Oct 04, 2024Tutor
RS700 losing internet connectivity
I installed the RS700 last month. Wireless and newly connected devices connect to WiFi and internal network instantly, but it take another 1 to 2 minutes before they have internet connectivity. ...
Baily
Oct 07, 2024Tutor
The Spectrum internet cable modem is an Arris DG1670A.
The cable modem worked fine with our old Netgear N600 router.
I've been able to validate that multiple devices (both wireless and cable connected) lose internet access multiple times throughout the day for maybe 30 to 90 seconds.
Oct 07, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
