Shunpiker
Oct 19, 2023Tutor
RS700 Mesh Support
I just received my (2) RS700 units and the setup of the first one went flawlessly. Due to the location of my office where my internet connection comes into the house, I need to use a mesh system to c...
- Nov 12, 2023
I'll just add from my experience that I had issues in setting up the 2nd unit in AP mode via wireless and finally connected via ethernet cable to a laptop and it worked without an issue.
BH_C
Oct 19, 2023NETGEAR Expert
I don't have the ETA for the Mesh support yet. But in your case where you use an Ethernet cable to connect the two Nighthawk routers, you can set the 2nd Nighthawk router (i.e. the one that is NOT directly connected to your modem) to the AP mode with the same WiFi network name (SSID) for now.
- ShunpikerOct 19, 2023Tutor
Thanks very much for the tip, I'll give it a try this weekend.
- FURRYe38Nov 12, 2023Guru - Experienced User
Yes if you have a 2nd RS, you have to set it up to get into the RS web page, then set AP Mode.
- ShunpikerNov 12, 2023Tutor
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
