tamayok
Sep 29, 2024Aspirant
RS700 Nighthawk BE19000 - Port forwarding not working, even after new Firmware Version V1.0.7.86_2.0
My new RS700 Nighthawk BE19000 - Port forwarding not working, even after updating to the new Firmware Version V1.0.7.86_2.0 I have rebooted computers, router/modem many times and now also disable...
ShadowMario3
Sep 29, 2024Luminary
Have no issues with port forwarding custom ports on my RS700 on the latest firmware (1.0.7.86). Have you tried seeing if another router is able to port forward the same port, and if it can, have you tried reaching out to Netgear to see if they can help you resolve the issue?
tamayok
Beyond: Advanced Setup > Port Forwarding and input of the custom service, port # and internal IP. Where else have you configured the RS700 in order to get Port Forwards working?
- ShadowMario3Sep 30, 2024Luminary
tamayok wrote:Beyond: Advanced Setup > Port Forwarding and input of the custom service, port # and internal IP. Where else have you configured the RS700 in order to get Port Forwards working?
I haven't configured port forwarding anywhere else. Advanced Setup > Port Forwarding was the only location I needed to worry about.
- tamayokSep 30, 2024Aspirant
Thanks for the reply. I thought so but wanted to make sure the Netgear didn't require multi-steps for setting port-forwarding (other than those in the dedicated form: internal IP, ext-int Port #, etc)
