Johnski3000
Jan 13, 2025Aspirant
RS700 not accepting 5GZ login from win 10 laptop
I recently installed a RS700 router, and set up separate SSIDs for the three bands so my legacy equipment can sync up. I also manually changed the bands for 2.4 and 5Gz, and 6ghz since a neighbors ro...
Jan 13, 2025Guru - Experienced User
Is WPA3 security enabled on the router?
What happens if you set NONE for wifi security for 5Ghz temporarily then try to connect the PC? Re-enable WPA2 after testing.
What brand and model# is the Windows 10 Wireless adapter?
Be sure that you do change the SSID name to something other than the default one. Make is simple and easy to see on devices.
What FW is loaded on the router?
- Johnski3000Jan 13, 2025Aspirant
I changed to WP2 and am now able to log in on 5Ghz. One problem solved Thanks
Firmware version is V1.0.7.86_2.0.82.
Still having other issues. But I will post in a new post.
- FURRYe38Jan 13, 2025Guru - Experienced User
Was the prior setting set for WPA2 and WPA3 mixed mode?
