nooope307
Apr 03, 2024Tutor
RS700 not connecting to internet
Hello, I recently purchased a Nighthawk RS700 to set up with my Charter Spectrum internet. Working with 500 MB/s down and I wanted to boost the signal in my house. I cannot get the RS700 to find ...
- Apr 03, 2024
I managed to find the answer. I dont think the RS700 is capable of handling the Cat8 cable I was using on the AR500. I switched the modem to router cable to the provided Cat 6 cable in the box. Now I have internet connection.
Apr 03, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
nooope307
Apr 03, 2024Tutor
Appreciate the response; see my third comment. It was the LAN cable. I had to drop from Cat8 to Cat6.
- FURRYe38Apr 03, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
