Topology's avatar
Topology
Virtuoso
Nov 14, 2023
RS700 versus RS700S
NETGEAR references two different model numbers (RS700 and RS700S) for the Nighthawk Tri-Band WiFi 7 Router (see here).  What are the differences, if any, between the two?
Thank you.
  • BH_C's avatar
    BH_C
    Nov 14, 2023
    Yes, all the answers above are correct. RS700S is the product name or SKU name, its hardware device is RS700. The appendix 'S' indicates 1-yr Armor service is bundled. There are no RS700 alone products in the market at this point. If you look at the RS700S' device label, it still says RS700. I hope this explains.
  • FURRYe38's avatar
    One comes with Armor subscription I do believe.
  • I think they are one in the same. I pre-ordered the RS700S, but I ended up getting the RS700.
    FURRYe38is likely right. My one did come with a year of Netgear Armor, so maybe all physical models are RS700, and the S just indicates that it comes with a year of armor.
    • FURRYe38's avatar
      The HW is the same. Just Software options Like Armor sets the S. NG does this for the Orbi system as well.
      • BH_C's avatar
        BH_C
        NETGEAR Expert
