Taldren
Jan 14, 2024Initiate
RS700 WAN aggregation, but no Failover option?
I have the following hardware: Netgear LM1200 - LTE Modem Netgear CM2000 - Cable Modem Netgear RS700 During the pandemic, like many, my company swapped to a remote or hybrid model. That means ...
ShadowMario3
Jan 14, 2024Luminary
It is unfortunate that this router doesn't have failover, and who knows if future routers will come with it.
I did end up buying a Netgear PR60X which has failover. You can also look into a TP-Link ER8411 as well. Both options will require you to buy a at least one SFP+ transceiver to make use of 10 gig LAN.
Taldren
Like I said, if the hardware/software can do aggregation, it can also do failover. This is just a software feature request which could be pushed out as a firmware update on existing products.
- BH_CJan 15, 2024NETGEAR Expert
Feature request well received. I've added it to my list. Thank you.
