Taldren
Jan 14, 2024Initiate
RS700 WAN aggregation, but no Failover option?
I have the following hardware: Netgear LM1200 - LTE Modem Netgear CM2000 - Cable Modem Netgear RS700 During the pandemic, like many, my company swapped to a remote or hybrid model. That means ...
Topology
Jan 15, 2024Virtuoso
Taldren, until such time as NETGEAR manufacturers a version of the LM1200 with better throughput (or preferably adds dual-WAN capabilities to consumer routers), you wish to explore adapters available from Cradlepoint (e.g., W1850).
- TopologyJan 15, 2024Virtuoso
ShadowMario3, what is your experience with the WAN failover/failback performance of the NETGEAR PR60X - i.e., how well does it work?
Thank you.
- ShadowMario3Jan 15, 2024Luminary
TopologyHad no issue at all from the one time I needed it so far. When I upgraded my fiber connection speed, I had a bit of down time with it, so that was my first real use of the failover with the PR60X. My computers instantly switched over to the cable connection. Once my fiber line was back up, it took a few seconds for it to switch back.
After doing a quick test with a constant ping to Google's DNS, there was no drop when it did the failover. When I switched the main WAN back on, there was only one packet loss.
