emr88
Dec 16, 2024Aspirant
RS700 Web Interface
I can access my Nighthawk gaming router via the Nighthawk app on my Android phone. I can view the IP address in the Nighthawk app, but when I ping the IP address on my computer there is no response...
Dec 16, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Can you log into 192.168.1.1 or 10.0.0.1 with any browser? Try MS Edge or Firefox?
Be sure to clear out all browser caches before.
Happens with a different PC?
emr88
Thanks for your reply. Current firmware is 1.0.7.87. I use a Firewalla Gold that is connected to Verizon FiOS. I do have a good quality cable and have had no issues with the RS700 until I tried to connect via the web interface. I used the External IP address listed on the Internet Port page in the Nighthawk app.
- FURRYe38Dec 16, 2024Guru - Experienced User
Try the internal LAN side IP address.
- Coliuto99Dec 27, 2024Tutor
emr88 wrote:Thanks for your reply. Current firmware is 1.0.7.87. I use a Firewalla Gold that is connected to Verizon FiOS. I do have a good quality cable and have had no issues with the RS700 until I tried to connect via the web interface. I used the External IP address listed on the Internet Port page in the Nighthawk app.
Where did you get that firmware?On the web site the latest version is the 1.0.7.86
