mman3222's avatar
Jun 19, 2024
RS7000S NOT working with Pi-hole. Bug Report.
I have been running a Raspberry Pi with Pi-hole installed for years. Absolutely ZERO issues with all the routers I've had over the last 5 years.    My Netgear RS7000S is running the latest Firmware...
  • mman3222's avatar
    Jun 21, 2024
    Well, here is one for the books.
    All the websites and forum posts say to enter your Pi-hole's IP address as the DNS server in your Netgear router's setting. That is absolutely NOT true!
    Every post said "Go to Internet > DNS > enter in your Pi-Hole's IP addresss (in my case, 192.168.1.2.)
    That is NOT the case with Netgear routers!
    Instead, I had to use Public DNS servers. I used 1.1.1.1 and 1.0.0.1.
    Then, go to Advanced > Setup > LAN Setup > DISABLE DHCP.
    Enable DHCP in your Pi-hole. Once you do that, then only will your deviecs on your network be told that your DHCP server is your Pi-hole IP address AND your DNS server will also be handed out my your Pi-hole!
    Now when I run a "ipconfig /all" in my Windows box, I see that Pi-hole (192.168.1.2) is the DHCP server AND the DNS server.
    Everything is working as intended now.
    Sheesh, Netgear! Get your stuff together!
    Problem solved! I hop this helps someone in the future on Google 🙂
