stanfrench
Aug 22, 2024Luminary
RS700S not delivering 1.5Gbps
I recently upgraded my modem and router so I could add more devices and get higher speeds. I purchased the Netgear Nighthawk CM2000 cable modem and the Nighthawk RS700S Wifi 7 router. According to th...
stanfrench
Aug 24, 2024Luminary
Hi BobbyP,
I checked the link speeds in the Device Manager of the Nighthawk app as you suggested and here's the result for my devices :
- iPad Pro: 2215 Mbps (40% reduction is 1,330 Mbps) at 6GHz. ST= 1,017 Mbps.
- iPad Pro: 1876 Mbps (40% reduction is 1,125 Mbps) at 5GHz. ST= 804 Mbps.
- iPhone 14: 1055 Mbps (40% reduction is 633 Mbps) at 5GHz. ST= 575 Mbps.
- Macbook: 1172 Mbps (40% reduction is 703 Mbps) at 5GHz. ST=785 Mbps.
The actual speed from the Speedtest app (ST) is next to each one.
The figures improve as I get closer to the router. I did try a 2.5 Gbps USB-C adapter with my Macbook and iPad (iMac too). For some reason I can't understand, it capped out at 940 Mbps on all, even the iPad which can get almost 1,100 Mbps wirelessly. Any thoughts on why the ethernet speeds are capped?
Thanks,
Stan
Aug 26, 2024Guru - Experienced User
What brand and model ethernet adapter are you using?
What speeds does it support.
Tried different ethernet supporting PCs to compare speed results?
