stanfrench
Aug 22, 2024Luminary
RS700S not delivering 1.5Gbps
I recently upgraded my modem and router so I could add more devices and get higher speeds. I purchased the Netgear Nighthawk CM2000 cable modem and the Nighthawk RS700S Wifi 7 router. According to th...
Aug 26, 2024Guru - Experienced User
How is the RS configured on it's basic and Advanced Wireless settings?
Channel configurations currently used?
Is Smart Connect enabled or disabled?
Is MIMO enabled under Advanced Wireless Settings?
stanfrench
Aug 26, 2024Luminary
I'm using 2.4 GHz, 5 GHz and 6 GHz channels. Guest is disabled. Smart connect is also disabled. MU-MIMO and OFDMA are both enabled.
I tried to disable OFDMA and just keep MU-MIMO but it's not possible. It seems Netgear only gives me the possibility to disable both MU-MIMO and OFDMA -or- disable just MU-MIMO but keep OFDMA. Disabling OFDMA and keeping MU-MIMO is not possible.
I attached a PDF of my basic and advanced wireless settings. Any suggestions on my settings?
- FURRYe38Aug 26, 2024Guru - Experienced User
What speeds are seen if you enabled Smart connect, leaving MIMO and OFDMA enabled?
MIMO I believe is needed to see faster speeds over wifi.
Try the following channels as well, 1 on 2.4Ghz, 40 on 5Ghz and 69(PSC) on 6Ghz.
- stanfrenchAug 26, 2024Luminary
Bingo! Changing the channel assignments from Auto to 1, 40 and 69(PSC) for 2.4 GHz, 5 GHz and 6GHz respectively did it. Thank you so much. I just ran a speed test and got 1,315 Mbps standing next to the router (incoming to the router was 1,630). 80% throughput works for me.
Apple suggests a single-name SSID (i.e., Smartconnect) but I'm reluctant to do that as I have a large coverage area and not sure how smart the connection really is. I'm glad I don't have to go to that step as it would involve a lot of device reconfiguring.
All is good now, thanks again.
Woo Hoo.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
